My Colors Seem Off
Forum Archive My Colors Seem Off
  • #16407
    Rako
      Hello,
      Great tutorial so far!
      I have a small, but distracting, problem.
      I’m using Blender 3.5. And I have also removed the camera and lights.
      My colors seem off, but I used the exact color numbers as in the tutorial, and I am in the Material Preview mode, which I think is the same as Look Dev mode, but I’m not sure now. colors seem off.png
      #79376
        If the color values are the same, then it has to do with the visualization itself. Maybe the viewport, maybe the color management.Try changing the color management from Filmic to Standard of vice versa.
        You can also have a different scene world doing the lighting for you. Try changing it.
        But in the end, you don’t need to have the exact same result, things like that will vary and it’s ok. The important thing is to learn the tool so you can create your own content. Sheers 🤟🏼
        #79377
          Hi @trial1010101010999 ,
          Please have a look at this post:
          https://cgcookie.com/community/11017-colors-are-looking-really-wrong
          #79378
          Rako
            Thanks so much for the answers!
            I switched the View Transform, under Color Management, to Standard and that got it close enough.
            I agree that I don’t need to get the exact values in a tutorial, but alarm bells were ringing when I was using exact values and the results weren’t similar. If I set Blender up improperly, then I would like to make sure to get that fixed before I end up learning the wrong way of doing things.
            Thanks again!
          • The topic ‘My Colors Seem Off’ is closed to new replies.
