Mort Polybook
Forum Archive Mort Polybook
Viewing 15 posts - 1 through 15 (of 15 total)
  • #20361
    Mort Larceny
      Tutorial scifi cube lets gooo
      #95613
      Mort Larceny
        A speaker on my desk
        #95614
          Excellent start, Mort!
          And kudos on making the speaker. It’s a great practice to apply the learned techniques to your own (little) projects!
          #95615
            Making good pace Mort 🤙🏼
            #95616
            Mort Larceny
              The Ball
              #95617
              Mort Larceny
                I made a cologne bottle to practice the bevel modifier! On the dispenser and cap I used two bevel modifiers, one that is just around the edges that creates the inward slope, and then one that adds a small bevel to everything. The image on the right is with all the modifiers disabled.
                This will be a good one to revisit when I dive into materials, and also when I get some more insight into a good way to get a circle where the dispenser would spray out, which right now I just left as a square.
                #95618
                Mort Larceny
                  Took an attempt at the hard drive before watching the tutorial for it, though I got pretty lazy with the B at the end. I used mostly boolean modifiers and some bevels for the main form. I think seeing the “solution” will be very helpful, since this was kinda challenging trying to approach this on my own.
                  #95619
                    That’s a great result!
                    Booleans and Bevels are the main players in the ‘Tutorial version’ as well😉
                    #95620
                      That is a great initiative. You learn so much more when you approach courses this way when ever possible.
                      #95621
                      Mort Larceny
                        Here’s the hard drive following the tutorial! A lot of these methods were so much more efficient then what I initially did. The big takeaways were using the array modifier for the holes, where I initially just did a checker deselect and extruded inwards, and also just using the solidify modifier for a clean and adjustable shell. Also using the text rather then trying to model the B by hand is way better.
                        #95622
                        Mort Larceny
                          Mugs!
                          #95623
                            Oh I like the personality of those mugs, the one on the left looks great.
                            #95624
                              They look great and they also seem to have nice Topology!
                              #95625
                              Mort Larceny
                                The Cookie
                                #95626
                                  That turned out really well Mort!
                                • The topic ‘Mort Polybook’ is closed to new replies.
