missing pngs
Forum Archive missing pngs
Viewing 10 posts - 1 through 10 (of 10 total)
  • #18427
    sheila5
      I redownloaded the coursefiles, but there are some icons missing from the zipped file
      Path ‘J:\AppData\Local\Temp\Brush Icons\Pencil_Red.png’ not found
      Path ‘J:\AppData\Local\Temp\Brush Icons\Pencil_Grey.png’ not found
      Path ‘J:\Documents\Dropbox\texture library\brushes\GP Brushes\GP Icons\gp_brush_chisel.png’ not found
      Path ‘J:\Dropbox\texture library\brushes\GP Brushes\GP Icons\HT20pc_Marker.png’ not found
      Path ‘J:\Dropbox\texture library\brushes\GP Brushes\GP Icons\HT50pc_Marker.png’ not found
      Path ‘J:\Dropbox\texture library\brushes\GP Brushes\GP Icons\HT90pc_Marker.png’ not found
      Path ‘J:\oefen\cgcookie\Brushes\Textures\Charcoal01.png’ not found
      Path ‘J:\Documents\Dropbox\texture library\paper\Gabrielle Paper\Gabrielle Paper (19).png’ not found
      Path ‘J:\Documents\Dropbox\texture library\brushes\GP Brushes\GP_Textures\Graphite2.png’ not found
      #87977
        Hm, Paul will know better, but the Icons show up for me, for instance:
        As you can see, it even changed the backslashes that Windows uses to forward slashes for me…
        (It appears to look at absolute paths in your file, but it should be relative paths…something like that, I don’t know…)
        #87978
        sheila5
          when I do ‘make paths relative’ it sais total files 30, changed 0, failed 0. and still not found. But the thing is I do see an icon of the pencil_red in red, same for the HT50pc_Marker
          well it’s probably not important. Thanks for looking into it Martin
          #87979
            Maybe you can try File > External Data > Find Missing Files?
            #87980
              At least it’s functional if it’s just the icons but the brushes work. In any case it would be great to have the icons. So yeah probably Paul will know when he wakes up tomorrow yesterday and sees this tomorrow now.
              #87981
              sheila5
                Files such as HT90pc_Marker.png are not on my pc Martin.
                #87982
                  Hey Sheila, can’t help you…let’s wait for Paul…he is very wise…I get it just fine:
                  #87983
                  coyo
                    Heya Sheila! This can be a sneaky one and this may or may not be a solution. Make sure the teeny box to the right of the icon window, the one that looks like a mountain and a sun, enabled (blue).
                    #87984
                    Paul Caggegi
                      Hi Sheila! Brushes have been tricky with Grease Pencil. I’ll check the extras folder for the course files and if necessary, place the texture files and icons in there with notes on how to use them. In the mean time, here are the missing PNGs you can download, save and assign locally.
                      rybrush Marker01.pngPencil_Blue.pngrybrush Marker02.pngHT90pc_Marker.pngHT50pc_Marker.pngHT20pc_Marker.pngPencil_Red.pngPencil_Grey.png
                      I am keeping an eye on Grease Pencil 3.0 as it develops. I am hoping its brush/icon system will be added to how sculpting brushes are stored.
                      #87985
                      sheila5
                        thanks @pcaggegi and the icon is activated @coyohti .
                      • The topic ‘missing pngs’ is closed to new replies.
