Hello!
I think Im running into some small version differences (using 4.1), but I want to make sure it’s not just a setting problem.
– When I hit “I” or select Insert Keyframe from the Object menu, the Insert Keyframe menu doesn’t pop up. It does, however, seem to automatically set the keyframe to location.
– When I open up the channels menu, I also see keyframes for Euler Rotation and Scale for all three axis’.
– When I adjusted the position of my camera, it also recorded that in the animation. I turned auto-keyframe off and it stopped doing this.
