Measure It – Distance between objects
Forum Archive Measure It – Distance between objects
  • #20598
    Nathi Tappan
      Sweet trick to measure from the top vertex to the floor! I never used those X,Y,Z buttons on Measure It!
      Also learned that it only works towards the origin of the object, so measuring the outlet towards the floor didn’t really work. But that can be so helpful! Particularly for models that share the same origin.
      On a side note: you can measure distances between objects in Measure It, though it has its quirks.
      You must select the vertex you would like to measure it from, then in the other object select the vertex you wish to measure it to. Then select both in object mode and hit the button “Link”.
      The downside is that if you don’t have vertices in the same plane you’ll end up with the actual distance, not limited to an axis. It’d be cool if both features were combined! It is handy if you do have vertices that already match and you don’t want to add any extra loop cuts to your model.
      #96484
         I tend to place a Cube in between the 2 Objects and Snap the sides of it in Edit Mode to the Objects (personally don’t need that enough for me to learn Measure It). The default Cube can be used for so many things in Blender 😃
        #96485
        Nathi Tappan
          Ha! True that!!
          And measure it is really very easy to use as a free add-on Martin. These are just extra features that can come in handy, but the basic usage is really simple.
          #96486
          Sascha Feider
            The link function is indeed a great tip.
            I do advise caution with it though, because of the exact quirk you already pointed out with vertices not being on the same plane. I remember vaguely running into some funkiness with it once, but I can’t remember where or what exactly.
            This would definitely something to doube-check on site.
            #96487
            Nathi Tappan
              Yeah, that is the bummer. The workaround would be always cutting more loops, which is a different bummer. But between more loops, the link function, and the good ole default cube methods, we’re bound to have at least one method that works for every scenario.
              #96488
              Sascha Feider
                Which is one of the main reasons why I separate the dimensions file from the actual modeling file. That way I can keep the modeling file as clean as possible.
                #96489
                Nathi Tappan
                  Good point!
                • The topic ‘Measure It – Distance between objects’ is closed to new replies.
