“making the bones fatter” using ctrl alt s doesn’t seem to change anything about them at all
Forum Archive “making the bones fatter” using ctrl alt s doesn’t seem to change anything about them at all
  • #11405
    frostheart10
      Hi,
      as title suggests when I try to scale them to make them easier to see, they don’t change at all, if I try scaling them on individual axis during it they begin to rotate… is my pivot point, or object centre perhaps which is the issue?
      http://pasteall.org/blend/index.php?id=52968 my file is here if this helps! Hope you cna help, I’m wondering if I done something wrong setting it up.
      #53300
      Wayne Dixon
        Hi Frostheart,
        It only changes the way they are displayed in b-bone mode.  Your file has the armature in Octohedral display mode.
        Try changing it to B-Bone
        #53301
        frostheart10
          Thank you for the swift reply, such a simple mistake on my end, oopsie!
        • The topic ‘“making the bones fatter” using ctrl alt s doesn’t seem to change anything about them at all’ is closed to new replies.
