Luna – Subdividing the arm/leg bones
Forum Archive Luna – Subdividing the arm/leg bones
  • #18113
    coyo
      Out of curiosity, what is the purpose of splitting the arm and leg bones? Is this to give more control to the bendy bones down the line and/or to give more control to rolls around the y-axis (for instance, to replicate the ulna/radius motion when rotating the hand)?
      Thanks!
      #86658
      Wayne Dixon
        Hi Coyo.
        Good question.
        The bendy limbs are for more control over the shape in animation (but not the roll of the radius and ulna)
        In super fast moves you can bend the limbs to help shape the flow in the movement.
        And in some normal non fast moves or poses even you can better shape the limbs for what you need.
        eg – It’s really easy to cross your arms in real life, but with a 3d character it can become difficult.
        This pose has a slight bend on the forearm to help shape the arm and hide the weird penetrations.
        #86659
        coyo
          Thanks for your reply! In your example would the two bones in the forearm be enough to recreate that pose? I’m asking since afaik Blender’s b-bones don’t export (gracefully) to other softwares (eg. game engines) so I am attempting to get a sense of what the limits are if I wish to export.
          #86660
          Wayne Dixon
            Yeah b-bones don’t export at all – they will just export as straight non-bendy versions.
            There are some (non-graceful) workarounds:
            • export the mesh cache and ignore the armature totally.
            • add a DEF for each b-bone segment and export the baked animation (a lot of work)
            • avoid b-bones when exporting the armature to a different software.
            But to answer your other question, you can actually create a bend in the arm with just 1 bone.  But that’s all it will be able to do (bend).
            If you split it into 2 bones. you have a lot more flexibility with the b-bones – like a massive amount.
            But splitting it further doesn’t add as much more flexibility than if it’s just 2 bones.
            (hope that makes sense)
          • The topic ‘Luna – Subdividing the arm/leg bones’ is closed to new replies.
