Luna Rig: Elbow_vis parenting conflict?
Forum Archive Luna Rig: Elbow_vis parenting conflict?
  • #18144
    coyo
      In the schematic for the arm Elbow_vis is shown as being parented to MCH-Forearm_switch. However, in the video you parent Elbow_vis to MCH-Forearm_IK which does seem to make more sense since a) the elbow is part of the IK structure and b) it works.
      Is the schematic incorrect or did I miss something along the way that would make that setup work? I am seriously second-guessing myself here. ^_^;
      #86778
      Wayne Dixon
        No I think you you found an error with the pdf.
        It should be parented to the IK chain as that is the mechanism that it affects.
        I’ll make a note of that and update it.
        Thank you.
        #86779
        sheila5
          it still says switch in the schematic
          #86780
          Wayne Dixon
            My bad, @sheila5
            The source files have now been updated.
            But here is a direct link to the updated arm schematics for your convenience
            https://www.dropbox.com/scl/fi/phbwvm46i0hp02ihnk3sz/arm-rig-schematics_v03.zip?rlkey=bb8kq1kxartshwsrzfqr886z2&dl=1
            #86781
            sheila5
              Thanks Wayne! I’ll double check if i have everything right also with the new schematics
              #86782
              Wayne Dixon
                If you are stuck or can’t figure something out, feel free to post it as your exercise and I can take a look.
              • The topic ‘Luna Rig: Elbow_vis parenting conflict?’ is closed to new replies.
