Looptools Circle is more of an oval
Forum Archive Looptools Circle is more of an oval
  • #7606
    Hamish Ames
      Hello,
      I have tried many different options, ie. smoothing, scaling edges to the z and y axis before using loop tools, rotating, playing with settings. But the Loop tools always leaves me with an oval rather than a circle, It looks ok’ish  when it is just the hole, but when adding the screw it looks really out of whack having an oval screw head.
      Thanks
      #27369
      Jonathan Lampel
        Hey Hamish, I’ve had a bit of trouble with this operator recently as well, so if it keeps giving you issues then it may be better to add a new circle as reference and just manually line up the vertices to that.
      • The topic ‘Looptools Circle is more of an oval’ is closed to new replies.
