loop with constant interpolation
Forum Archive loop with constant interpolation
  • #14317
    Goran Svensson
      For this exercise I put the last keyframe just behind the end (to create perfect loop).
      The videos on vimeo only play once, so the square never return to the initial spot if the video does not restart.
      I got critique on the loop. Two reviewers said the square never returned to its original spot.
      Did I set up things correct, but was unfortunate that vimeo does not loop videos automatically?
      #70320
      Wayne Dixon
        Hi Goran,
        Vimeo used to let you make it loop automatically, but I don’t think you can do that anymore. Stupid Vimeo.
        But it sounds like you know exactly what prompted that response from the reviewers, so don’t worry about it.
        It’s important to realise that while feedback is critical for improvement, not all feedback is strictly on point.
        It’s up to you, the creator, to interpret and figure out what the underlying reason why they gave that feedback.
        Sometimes it’s not accurate, sometimes it’s exactly on point and sometimes it’s in the right ballpark but doesn’t tell you the underlying reason.
        In this instance, it doesn’t diagnose the underlying reason that provoked that response, but you did.  You figured it out.
        If you want to loop your videos, you can use extend the timeline and use a cycle modifier
        or here’s a video on how to use the VSE to loop one of your videos.
        https://cgcookie.com/tutorial/how-to-loop-an-animation-clip-with-the-blender-vse
        Hope this helps.
      • The topic ‘loop with constant interpolation’ is closed to new replies.
