loop cut of the separated mesh
Forum Archive loop cut of the separated mesh
  • #7099
    alex starub
      at 6:15  how can you add the loop cut on the top face screw troughout the mesh if you have already separated vertices with the V?
      #26513
      Jacek Zakowicz
        Alex, I think that Jonathan did not separate those elements/edges by using V in the end. He is doing it one or two lessons ahead.
        Or I am missing something here because CTRL+R do not go through separated edges, just tired it to make sure.
      • The topic ‘loop cut of the separated mesh’ is closed to new replies.
