Loop cut and slide in Blender 2.81 and 2.82 (for thruster)
Forum Archive Loop cut and slide in Blender 2.81 and 2.82 (for thruster)
  • #11472
    Ido Reshef
      Hello,
      In the Blender 2.81 and 2.82 you can’t add more loops with the scroll wheel anymore with hitting CTRL+R or selecting the icon( :/) . But there is a workaround – In order to do it – Select the edge that suppose to get cut , right click, choose “Loop cut and slide” and then you will get the “old” functionality portrayed in the video.
      For more details:
      https://blender.stackexchange.com/questions/148039/using-the-loop-cut-and-adding-additional-loops
      All the best,
      Ido
      #53519
        That is only if you use the Industry Compatible keymap! Normal Blender users can still use CTRL+R and scrolling with the mouse wheel.
        #53520
        Ido Reshef
          Hi,
          I have experienced with the different keymaps following your answer. It turns out I use the “Blender” keymap scheme. Only when I switch to “Blender 2.7x” keymap I get the desired functionality back.
          Anyway your answer shed a clue to the cause of this, so thanks !
          All the best.
          #53521
          Shawn Blanch
            That’s funny. Ctrl + R works fine for me and I have just plain Jane blender 2.82 settings. I can scroll multiple loop cuts without issue.
            #53522
              That is really strange. I’ve tried it with all three Keymaps and only Industry Compatible was different in this behavior…
            • The topic ‘Loop cut and slide in Blender 2.81 and 2.82 (for thruster)’ is closed to new replies.
