Large fields. Composite or straight render?
Forum Archive Large fields. Composite or straight render?
  • #6333
    Peter Robie
      I have a scene that I’m working on and the size of the plane is 272’x272′ (imperial) and currently has no sculpting on it. Since it’s a pretty large scene I’m wondering if I should separate the various sections or try to render it out as a whole using this process or would another option be better for such a large scene?
      #25240
      Jonathan Lampel
        Hey Peter, that’s a huge scene! Try using this technique, which limits the scene to only what the camera sees: https://youtu.be/9tKHZFLbtUI?t=16m19s
        If that doesn’t do it, post what it looks like in the Community and we can help you out.
        #25241
        Peter Robie
          Thanks Jonathan. The idea that I working on is basically an adaptation of Danvers State Hospital in Danvers, Mass. The estimated height to the top most peak is 130′. The scene opens with a wide shot of the main building and additional buildings on the side. Being such a large building the camera has to be quite a ways away to be able to capture it. Of course there is a lot of grass so that’s been my biggest challenge.
        • The topic ‘Large fields. Composite or straight render?’ is closed to new replies.
