Labels / anAtomic Lex tab missing
Forum Archive Labels / anAtomic Lex tab missing
  • #16344
    Tobias Krause
      Hi… when I open the anatomic lex model and open it in Blender 3.5 I don’t see the labels and the “anAtomic Lex” tab is missing… at least I saw this tab in one of the videos. Should it be there? Which Blender version might I need to use for this? I also had a look on the material and thought tweaking the value for the “Fat Labels Value” in ecorche_fat_basic material for example might help but no label show up…
      #79107
        Hi @tobitaurus ,
        apparently there has been a change in the Python version/API and the script won’t run as it is anymore…
        I don’t know Python and can’t find what needs to be changed, but in Blender 3.3LTS, it still works. In 3.4 it’s ‘broken’.
        #79108
        Adrian Bellworthy
          Hey @tobitaurus,
          The issue in the script is because of the new color mix node,
          The FAC input changed name to FACTOR.
           Open a text editor window and click the ‘Browse Script’ menu at the top, the anatomic-lex_UI.py script should be there, select it.
          On lines 42, 43 and 44 you will see at the end of each line .inputs[‘Fac’], change the Fac to Factor.
          Then click run script.
          The UI tab should now appear.
          Save the file, this will save the updated script also.
          #79109
            Fantastic Adrian! 💯💯💯
            #79110
            Tobias Krause
              Thank you Adrian… another point for me to keep in mind: you need to be in material preview mode, not in solid view mode 🙂 oviously…
              What remains now that I don’t see the skin… but this is less important
              #79111
                Hot dangs Adrian is a magician. Nice one Adrian.
                #79112
                  Hey Team – I just uploaded v1.0.3 of the anatomic “Lex” file, which corrected for the Fac VS Factor syntax. It’s available in the course downloads:
                  as well as the Downloads page. Sorry for the confusion!
                • The topic ‘Labels / anAtomic Lex tab missing’ is closed to new replies.
