Kind of confused on what the constant offset is? and what is the difference between the constant and relative offset is.
Forum Archive Kind of confused on what the constant offset is? and what is the difference between the constant and relative offset is.
  • #5480
    Corey Birch
      #23938
      Aunnop Kattiyanet
        Think about you have a cube with dimensions of 2.5*3.5*4.5 unit
        Relative offset will set the distance for each cube by 2.5(x axis) automatically[relative offset of 1 (if 3, distance is 3*2.5 = 7.5 unit)].
        But constant offset the distance is rely on the value you set, if 1 in x axis, the distance from first cube and the next is 1 unit.
        Hope that helps 🙂
      • The topic ‘Kind of confused on what the constant offset is? and what is the difference between the constant and relative offset is.’ is closed to new replies.
