I found that when trying to align the inner part of the hard drive that we extruded from two top faces of the outer shell, trying to get that inner bevel to match the bevel of the outer shell of the hard drive wasn’t working properly.
I went back and double-checked the tutorial and the result that is in the tutorial is only matching if I leave clamp override off with 1.9cm on the bevel.
Clamping results in messing up that inner bevel and Im not sure why.
Pretty sure I followed everything else exactly.
