It's not actually a question. I have learned a long time ago another another technique to animate a perfect circle and I'd…
Forum Archive It's not actually a question. I have learned a long time ago another another technique to animate a perfect circle and I'd…
  • #5900
    mrf28
      It’s not actually a question. I have learned a long time ago another another technique to animate a perfect circle and I’d like to share here.
      1. Add a curve>circle and make it to your desired position and size.
      #24539
      mrf28
        oops…
        #24540
        mrf28
          continuing…
          2. Select the object you want to animate and then the curve and hit Ctrl+P then choose “Follow Path”
          3. Tweak the desired amount of frames in the curve properties.
          4. The object should already moving but rotating as it follows the path, so you can lock its rotation with a “limit rotation” constraint.
          #24541
          Wayne Dixon
            The idea is to get used to the graph editor 😉
          • The topic ‘It's not actually a question. I have learned a long time ago another another technique to animate a perfect circle and I'd…’ is closed to new replies.
