Issue with uv unwrap on the rim of the chest / all grouped
Forum Archive Issue with uv unwrap on the rim of the chest / all grouped
  • #11260
    Nick Bell
      https://www.youtube.com/watch?v=HWXNSk1VHQ0
      (hope I set it up right this time to view)
      The mesh seems to think that there is a seam in places its not. not sure how to fix.
      the other issue is when it is all grouped. the rim does not show the tile texture not sure what i did.
      https://www.youtube.com/watch?v=AHEhxcqWX1A
      Note I have been going through the videos and on my own for a day or two now and can’t see what i did wrong.
      #52824
        Thanks for taking the time to explain your issues with videos. It helps a lot for me to understand context and brainstorm a solution. I think I’ve seen that UV issue before but I can’t remember how to solve it. The rim tile texture issue seems like there’s 2 texture slots assigned to different parts of the mesh.
        Could you provide a download link for your .blend file? The best way to do this is by uploading to Dropbox, Google Drive, or similar hosting service then copying + pasting a share link. Also please pack your .blend file before saving and uploading (File > External Data > Pack all into .blend).
        #52825
        Nick Bell
          Hey Kent
          thanks for taking the time to have a look.
          https://drive.google.com/open?id=1-SxRcY-uVj0HeEf5VOQuM7Atiovw3T6P
          #52826
            Hi Legacy Of Wax, I don’t know exactly what you did, but if you select the metal rim and select all in Edit Mode and Unwrap again, the issue is solved (maybe you unwrapped when only that single face was selected, or something.
            The other issue, is just because the metal rims have no Material.
            Hope that helps.
            #52827
            Nick Bell
              Thank you so much for the help again, seems to have fixed the issue.
              Hope using this program gets easier as i go.
              #52828
                @legacyofwax Don’t worry, it will get easier!
                #52829
                Shawn Blanch
                  @legacyofwax Frustrations lead to breakthroughs eventually. Mistakes are bound to happen. The fact that you have spent a decent amount of time shows your dedication. Keep at it. I remember being a complete noob, and have only recently graduated to still kind-of-a-noob.
                  This community is great though. If you want to contact someone specifically for a question like Kent you can use the @ mention and their name (the blue highlighted name next to the user name if there are two names). So Kent’s would be: the @ symbol and then type:  theluthier
                  for example mine is @blanchsb
                  This will send a notification to that user next time they log in. Hope that helps for future help requests.
                • The topic ‘Issue with uv unwrap on the rim of the chest / all grouped’ is closed to new replies.
