Is there any way to save an image after post-processing instead of rendering it again?
Forum Archive Is there any way to save an image after post-processing instead of rendering it again?
  • #5079
    ihennessy1338
      #23425
        @ihennessy1338 Yes – In the UV/Image editor, if you see your post-processed image, you can go to Image > Save as Image.
        If you don’t see your post-processed image, go to the Node Editor add an Output > Viewer node. Also check “Backdrop”.
        Then Jump back over to the UV/Image Editor and switch the source to be Viewer Node.
        Finally, go to Image > Save as Image to spit out an image file of your render.
      • The topic ‘Is there any way to save an image after post-processing instead of rendering it again?’ is closed to new replies.
