Is there an add-on or script to turn Edge and Face Info ON for all meshes in scene?
Forum Archive Is there an add-on or script to turn Edge and Face Info ON for all meshes in scene?
  • #7391
    Adam Janz
      Or can it only be toggled individually? Thanks
      #26995
      Jonathan Lampel
        There’s a somewhat hacky way to do it: select all meshes in object mode, enter edit mode on one of them, and hold Alt as you turn on the info. That will apply it to all selected objects. If you have Emulate 3 Button Mouse turned on in your user preferences, you’ll need to disable that momentarily while you do this, since it overrides the Alt key.
        #26996
        Adam Janz
           Thanks for that helpful tip!
        • The topic ‘Is there an add-on or script to turn Edge and Face Info ON for all meshes in scene?’ is closed to new replies.
