Is there a quick way to add a keyframe between two frames for in-betweening?
Forum Archive Is there a quick way to add a keyframe between two frames for in-betweening?
  • #8911
    ncollins1985
      Wayne Dixon
        Hi ncollins1985,
        Yes but it depends exactly on what you you want to do.
        You can get the computer to inbetween for you as long as it is using the same Grease Pencil (GP) points from both frames.
        Just go to the empty frame between your two frames, make sure you are in edit mode then press the interpolate button or Ctrl Alt E
        But if you have different GP points on both frames then that will not work.  You will have to draw that frame.
        So jump into Draw Mode and on the inbetween frame you can really quickly press, D and then B.  But you have to be fast. This will insert a blank frame and if you have onion skinning on it will make it easy to inbetween.
        (That is also located in Strokes>Animation>Insert Blank Frame)
        Is that what you mean?
        #29596
        ncollins1985
          That is. Thank you!
        • The topic ‘Is there a quick way to add a keyframe between two frames for in-betweening?’ is closed to new replies.
