The split that occurs in the corners after insetting has thrown me off a bit. Is there some way to achieve these insets while avoiding that splitting in the corners?
I’m just having trouble getting things to snap the way I want them to. If I switch to increment snapping, even while holding down shift I’m often unable to get the exact measurements that I want. For example I’ll be looking for the windows to be 5 mm from the building and I’ll be at 5.02 mm but the next smallest increment I can move to will be 4.97 or something other than 5.00 exactly.
