Yep as Martin did it, you need those holding edges. But you can also opt for not subdividing the model and working with the auto smooth/bevel/creasing technique. I think the Press Start course is the one that mostly uses those? Linking up:
So weird I found this – I was thinking about this EXACT problem. It seems simple, but there’s an elegance to the solution. Anyway, thanks – this cleared up some things.
Author
The topic ‘Is there a better way to model this? | Subdiv workflow “Semi-inset”’ is closed to new replies.
