Is there a better way to create the insets for a realistic laptop?
Forum Archive Is there a better way to create the insets for a realistic laptop?
  • #19781
    Sid Edwards
      I’m trying to model the base of a simple laptop.
      I was hoping to use Bevel Weight to turn sharp corners into rounded corners, but in a needed selective way.
      However, it doesn’t seem to do anything when the Bevel modifier is used after the subdivision surface modifier.
      So instead, I’m using the Creases with the subsurf modifier. This works nicely, but, it got me thinking whether there was a better way to do this.
      The base of a simple laptop has 2 insets: the keyboard and mouse.
      Therefore, I created 3 rectangles: the case, the keyboard and the mouse. Then I connected them using the F key. Then I started creasing to get selectively rounded corners.
      Is there a better way I should have been d23 200343 - Copy.pngoing this? The final result doesn’t look bad, but, it really seems like there should have been a way to use bevel properly on a low poly mesh. When I do actually now try to bevel, I get some pretty weird effects with the creases.
      #93475
        HI Sid,
        Did you watch this Course: https://cgcookie.com/lessons/laptop-modeling-the-body ?
        #93476
          Yeah the laptop course should set you right up.
          #93477
          Sid Edwards
            I had no idea that course existed, it’s not labeled in a way I thought to search for, thanks for bringing that up!
            #93478
            Sid Edwards
              Your website build in meta data to search results?
              When I search “laptop” or something like that in the search course filter, nothing comes up sometimes.
              #93479
                Yeah the site needs a little bit of better coding. Once day when there’s enough developers on the team we’ll get some well deserved features and fixes.
              • The topic ‘Is there a better way to create the insets for a realistic laptop?’ is closed to new replies.
