Is it possible to assign materials to specific polygons as well?
Forum Archive Is it possible to assign materials to specific polygons as well?
  • #18755
    Andrew L
      In this video, you show that you can apply a material to an object or linked components of a disconnected mesh, but can you also just highlight say a row of faces and apply a material to them?
      #89485
      Sascha Feider
        You sure can. Once you have created your materials in different slots as shown in the video, go into edit mode and select the faces you want to have the different material on. With those selected click on the material slot of choice and hit assign. So it’s the same process as before with linked components, whatever parts of the mesh you select you can give a new material, in this case the red cross on a white cube.024-09-15 225516.jpg
        #89486
          Yes, it is as Sascha explains. Things such as modifiers can alter the faces of your mesh and thus making funky things to materials, you have to be mindful of such things, but that’s for the future when you’re doing more complex things.
        • The topic ‘Is it possible to assign materials to specific polygons as well?’ is closed to new replies.
