Is it ok if we do the jump differently, and change the camera angle?
Forum Archive Is it ok if we do the jump differently, and change the camera angle?
  • #6665
    Zach Zellman
      Wayne Dixon
        Yes, but just so you know, changing the camera angle can change the spacing.
        (eg – jumping towards the camera Vs side view is very different)
        #25744
        Zach Zellman
          I was thinking of doing a running start to the jump, or just a step or two then jumping. Which would make Stomp’s profile face the camera. I would just move the camera over/rotate a little bit so it was a little more towards a 3/4 view, like you said in one of the workflow videos.
          #25745
          Wayne Dixon
            yep – 3/4 is ok.  But I was referring to favouring the camera (ie – angling your body towards the camera or ‘opening up’ towards the camera)
            But yes, that sounds ok.  Try not to go overboard and make it too complicated at first haha
          • The topic ‘Is it ok if we do the jump differently, and change the camera angle?’ is closed to new replies.
