Is Edge Slide good for Archviz?
Forum Archive Is Edge Slide good for Archviz?
  • #18507
    Joseph Lemons
      If you were making a wall that went around a corner, would you use an edge loop to make one part & then the second part using the loop rather then making the wall out of two pieces?
      #88394
      Dwayne Savage
        depends on the situation. If I’m planning modular then separate. Other wise one solid piece.
        #88395
          Yeah, it totally depends on what you want, but usually you’d want to make it one solid piece. I tend to go by real life when I’m modeling. So for example if you’re modeling a door and the door is one solid wooden piece, then I do it one solid mesh. And then the handle is a separate object, so I make it a separate object. That why when it comes to rigging and parenting, or having a hinge in the object, it all comes along naturally, since it’s based on how stuff is in real life.
          #88396
          Sascha Feider
            I usually handle it this way: On interior scenes I like keeping all the walls (incl. floor and ceiling) separate throughout the creation process of my scenes, simply because then I can just uncheck their visibility in the outliner depending on the area I’m working on and if they’re in the way. Makes it much more convenient in my opinion.
            Then as a final step before the final render I sometimes join them back together, sometimes not. It highly depends on the visibility of the corners and if it would be obvious, if there wasn’t a small bevel in the corner in the final render. That I do on a case by case basis.
            On exterior scenes I mostly keep them as one mesh, or sometimes separated by cladding type. That is if I don’t venture into the interior too much on the same scene. Again, like the others already said, it’s on a case by case basis.
          • The topic ‘Is Edge Slide good for Archviz?’ is closed to new replies.
