IOR for solid materials
Forum Archive IOR for solid materials
  • #12650
    Ingmar Franz
      I understand what IOR for transparent materials means: Index Of Refraction. But if the “Specular” value determines the IOR for solid materials, I have difficulties imagining a refraction. I associate “Specular” with “Glossy” and understand the value for “Specular” as the strength of that reflection. With the “Clearcoat” it’s different. I can imagine this as a transparent glass or plastic layer with some refraction. But you described it in this video as a second mixed in “Glossy Shader” so that there isn’t any layer thickness and therefore no IOR.
      #60092
      Jonathan Lampel
        Yep, it’s very weird. So IOR actually refers to the Complex Refractive Index and not just the Refractive Index. The Complex part of that refers to also taking into account the Extinction Coefficient, which is negligible in transparent materials but becomes important once light starts getting absorbed. You can read more about that here: https://en.wikipedia.org/wiki/Refractive_index#Dispersion
        I think I misspoke then – clearcoat is just added on top and not mixed in. Not really physically correct, but it works. You’re right though that it’s not influenced by the specular value or IOR.
        #60093
        Ingmar Franz
          So, with the “Clearcoat” beeing added, could this lead to a physically incorrect result where the PBR material reflects more light than it receives?
          #60094
          Jonathan Lampel
            Yep! It’s usually added by a very small amount so it’s not that noticeable, but it is technically physically incorrect.
          • The topic ‘IOR for solid materials’ is closed to new replies.
