Forum Archive › Inset previous thickness not saved
every time I use the Inset tool, the thickness is reset to 0.01
why do I need to do to make sure it saves the previous setting?
Hey Govy, I recently realized that it doesn’t save your input if you just adjust with the mouse and confirm, but it does save it if you type it in manually after confirming.
well, I did input it manually and saved.
is it perhaps a setting in the prefs that I don’t have enabled ?
Not that I can find, I think the difference is just between typing it manually or leaving it as-is after adjusting with the mouse.
