Inset for cartridge opening is splitting into two areas instead of one.
Forum Archive Inset for cartridge opening is splitting into two areas instead of one.
  • #19748
    Brian Watson
      What could be causing my inset to act as 2 areas instead of 1 as the video shows?  I believe I have selected the same faces as in the video, but when I inset I keep getting 2 insets — 1 upper and 1 lower area.  Do I possibly have extra vertices or edges that I can’t see?  I’ve select around each vertice, but merge vertices isn’t an option when I right click, which makes me think there are not multiple vertices.
      #93353
        ‘Double Vertices” are indeed the most likely cause.
        When you want to Merge ‘double Vertices’, you need to make sure that all are Selected.;use A to Select all, or switch to Wireframe Mode and then you can use Box Select (or Circle or Lasso Select).
        #93354
          Is merging in the right click button? Not sure but the hotkey is M and select merge by distance. Also you can may the inset set to “individual”. You can turn that off with “I” I believe.
          #93355
            Merge Vertices is in the RMB Context Menu, iff (if and only if) you are in Vertex Select Mode, I believe.
          • The topic ‘Inset for cartridge opening is splitting into two areas instead of one.’ is closed to new replies.
