Insert operation dont work properly
Forum Archive Insert operation dont work properly
Viewing 12 posts - 1 through 12 (of 12 total)
  • #14934
    maxcady
      I try to insert as the teacher but it does it badly. I tested all kind of things and I didnt find out why. Check the video. https://youtu.be/GL8UtdYqg90
      #73678
        Hi @maxcady the YT video is not ideal to troubleshoot issues like this (a few screen shots can be more helpful, or even a link to your .blend file), but This looks like you have inconsistent Normals.
        Select all (A) in Edit Mode (before Insetting) and then SHIFT+N.
        #73679
        maxcady
          thx. how to find the link to the blend file?
          #73680
            @maxcady you need to upload your .blend to Dropbox, googleDrive or so and then paste a link here.
            #73681
            maxcady
              thx. will do
              #73682
              maxcady
                I did recalculate the normal with Shift N in edit mode, and it doesnt work. Other solutions?
                Video
                and
                Blender file
                #73683
                  Hi @maxcady ,
                  This is a classical problem you have here: uneven Scale:
                  With the Handle in Object Mode, CTRL+A > Apply > Scale.
                  The side of the Handle is also very wobbly, if that is intentional, than that’s fine, otherwise, select the side and then S, Y, 0 to flatten it.
                  You might also want to switch the Pivot Point back to Median Point (is on Individual Origins at the moment).
                  #73684
                  maxcady
                    Thx. The model is not finished yet. So it’s not yet flatten. I will remember now to always apply the scale in object mode. How do you know it’s not median?
                    #73685
                      How do I know it’s not Median? You can see (and set) that here:
                      #73686
                      maxcady
                        Well I know that but I can’t see when it’s median or not. I don’t know what it means either since I just use Individual or 3D cursor for now.
                        #73687
                        Jonathan Lampel
                          Glad that worked! Here’s more info about pivot points, including median: https://cgcookie.com/lessons/pivot-points
                          #73688
                          maxcady
                            thx. I learned a bit.
                          • The topic ‘Insert operation dont work properly’ is closed to new replies.
