inflate + smooth vs simplify
Forum Archive inflate + smooth vs simplify
  • #21376
    pierluigi colombo
      Hi, i saw in the video that in order to refine a mesh a good workflow is inflate + smooth with dyntopo. Is this the primary target of the simplify brush? If i use the simplify brush with dyntopo with an edge lenght less than the actual edge lenght of the mesh, will i achieve the same result of inflate + smooth? or is it better to use inflate + smooth?
      #99654
        Hi Pierluigi,
        What do you mean by “refine a Mesh”?
        If it’s just to change the Resolution   of a part of the Mesh, you can use the Density (formerly called Simplify) Brush, or the Inflate with a Strength of 0. Those two methods would have the same effect. Inflate + Smooth is the ‘weirder’ variant, that wants to do the same, but first changes the shape and then tries to change it back with Smooth.
        So you have more than 1 opton. In fact, all Brushes that update the Topology wih Dyntopo, when used with a Strength of 0 have the same effect as the Density Brush.
      • The topic ‘inflate + smooth vs simplify’ is closed to new replies.
