In the tutorial on Sampling, Kent recommends in the seed, putting £frame – but it does not work from me. I am using 2.74 o…
Forum Archive In the tutorial on Sampling, Kent recommends in the seed, putting £frame – but it does not work from me. I am using 2.74 o…
  • #4247
    Chris Patch
      In the tutorial on Sampling, Kent recommends in the seed, putting £frame – but it does not work from me. I am using 2.74 on a Macbook Pro, opt 3 gives me £ symbol? Thanks
      #22205
        Sorry for the confusion – It should be #frame, so SHIFT + 3. Although as of 2.75, Blender has a handy built-in function to do this exact thing. It’s the little clock icon on the right side of the Seed property.
        #22206
        Chris Patch
          Hi Kent, I tried this and the seed button turned purple, however when I right arrow through the frames on the timeline, the number in the seed does not change (stays at zero)?? I tried downloading 2.75 but the link did not work and I can not see how to get to it, so I tried 2.76 but it stuffs up my existing rigify rig. Can you help in any way? thanks
          #22207
          Chris Patch
            Sorry Trent, all good, I have solved it with using 2.76. Thanks for your guidance.
          • The topic ‘In the tutorial on Sampling, Kent recommends in the seed, putting £frame – but it does not work from me. I am using 2.74 o…’ is closed to new replies.
