In the Print Resin lesson, the SSS only appears to be working with my CPU, but when I render it on my GPU, it turns absolu…
Forum Archive In the Print Resin lesson, the SSS only appears to be working with my CPU, but when I render it on my GPU, it turns absolu…
  • #5849
    Spicy Birb
      In the Print Resin lesson, the SSS only appears to be working with my CPU, but when I render it on my GPU, it turns absolutely black. My GPU is also leagues faster than my CPU
      #24455
        Hmm it sounds like possible GPU incompatibility? Have you checked it’s compatibility with Cycles? I personally don’t have a compatible GPU and can’t be much help..
      • The topic ‘In the Print Resin lesson, the SSS only appears to be working with my CPU, but when I render it on my GPU, it turns absolu…’ is closed to new replies.
