In the final lesson the textures are applied automatically to an imported FBX. You never explain why. And in fact, when I try this, it doesn’t work. Do I have to re-create the folder structure? Does it have to do with the naming scheme?
Typically the name comes from the mesh itself. So if you had a material called “rock” and another called “grass” it would then create two materials with those same names. If you didn’t apply a material sometimes it’ll just create one called “default material” or something along those lines.
Author
The topic ‘In the final lesson the textures are applied automatically to an imported FBX. You never explain why. And in fact, when I …’ is closed to new replies.
