in texture mode, my suzanne become totally white… Help ?
Forum Archive in texture mode, my suzanne become totally white… Help ?
Viewing 11 posts - 1 through 11 (of 11 total)
  • #6383
    galledark
      I’ve got a problem when i switch to texture mode to see the checker texture into Suzanne…. She becomes totally white, and i don’t kno why.
      I’ve noticed any mesh that i have become white when i switch into texture mode, even if i do nothing into them.
      For example: I go into blender, i’ve got my cube, i suppress the lamp, i switch into texture and…POOF, it becomes white. Same thing happened on suzanne.
      The problem is: Even if i follow the steps of the course… Nothing changed at all ! My mesh is still white when i switch into texture…
      If someone know what can causes this problem… ^^
      Ps: i use the elsyiun theme…. i don’t know if the problem can go from here… I’ve tried to switch into another theme into the user preferences but… Still white… 😮
      #25327
      galledark
        Ok after many tests i’ve found a solution:
        This problem seems happend only when you mark seams before the creation of the checker texture !
        In my case i’ve solve it like this:
        You can unwrap your mesh, (without any seam) and then create the checker texture
        Or you can create the checker texture first and unwrap your mesh (without any seam).
        But do NOT mark seam an edge without the texture… I don’t know why but this is what cause the problem of the white mesh for my case !
        #25328
          Thanks for following up with your discovery @galledark!
          #25329
          Michael Wanyoike
            I was facing the same problem in Blender render (am using 2.78), then I realized I needed to remove the texture, select all the faces then select the Texture again for it to show up on Suzanne.
            #25330
            graudhir
              Thank you soooo much!!
              #25331
              Calvin
                Thank you Yannis! Bookmarking this for sure
                #25332
                sargentpilcher
                  I’m probably 2 years too late, but I’m having the same problem, but even when I have no seams whatsoever I have the problem. Blender 2.79 any ideas?
                  #25333
                  sargentpilcher
                    I figured out the problem. In the top left tab “Slots” there is a checkmark box saying “mask” which must be enabled, and a drop down menu appears allowing me to select the same texture as the UV view.
                    #25334
                      Like I said in your other post, this is incorrect! This is how it should be:
                      #25335
                      Jonathan Nunez
                        this literally helped me, thank you!
                        #25336
                        Mark Smith
                          that’s a good example of why posting a found solution is important…
                        • The topic ‘in texture mode, my suzanne become totally white… Help ?’ is closed to new replies.
