In properties of the metaball, I can change the number of the ball type but the look doesn’t change. It remains a football. Is this because I’m using Blender 2.79 or could it be due to something else?
Forum Archive In properties of the metaball, I can change the number of the ball type but the look doesn’t change. It remains a football. Is this because I’m using Blender 2.79 or could it be due to something else?
  • #7321
    alispark
      Wayne Dixon
        You most likely have an error at the top when you open the file.
        Click “Reload Trusted” and it will relaunch w/o the drivers being disabled.
        Also make sure you have ‘auto run python scripts’ checked in your user preferences.
        (User Prefs> File > Auto Run Python Scripts)
        #26891
        Jonathan Lampel
          From Alison (replying to the email sends a message to support – we haven’t integrated email replies into the site just yet):
          Thanks for replying. When I first open the file, there are 2 pages: The first shows 01 in top right corner on a white rectangular background. This area is over a grey space with the football in the top left-hand corner. No menus visible (unless I click on any one of the 3 +s ). I close this to see a more usual type page beneath.
          That page had Autorun disable and reload trusted at top. I clicked on reload trusted > Ok? Revert. The first screen reappears. I closed that. I see a blender page beneath. I select the ball. Under Item is just Ball_2_plainball.
          Now there are not even any numbers to choose from, and certainly no different ball types.
          I then went to user prefs > File > Auto run Python Scripts I selected and closed that box. This seems to have made no difference. No other types of ball available. I don’t have a Multi-ball UI panel. Even when I enable python scripts first, and save that, and reopen the file, and run python scripts: this no longer shows ‘Autorun disable’ but otherwise seems to make no difference.
        • The topic ‘In properties of the metaball, I can change the number of the ball type but the look doesn’t change. It remains a football. Is this because I’m using Blender 2.79 or could it be due to something else?’ is closed to new replies.
