In Generating Stand Supports Set Radius Curve is not working
Forum Archive In Generating Stand Supports Set Radius Curve is not working
  • #20711
    Nitin Sharma
      I’m using latest version of Blender 4.5.2 LTS and in this I’m facing problem in this session of Generating Stand Supports in Set Radius Curve node as it not showing any result. Please help me how can I fix this
      #96931
        Hi Nitin @Nitin2001 ,
        Next time, please add a timestamp.
        The Curve to Mesh Node now has a Scale Input, that accepts a Field. You can use that instead of the Set Curve Radius.
        You’ll have to change that inside the Curve to Beam Group, something like so:
        #96932
        Nitin Sharma
          Hii Martin
          Timestamp is 10:20
          In this node Set Curve Radius is not working this screenshot is from Tutorial. I also have used same but no results also I have tried the above method that also showing no results. Please check and help me in this.
          #96933
            So, it’s like this (for instance, there are, of course, other possibilities):
            #96934
            Nitin Sharma
              Thanks Martin now it is working.
              Thanks for your support
            • The topic ‘In Generating Stand Supports Set Radius Curve is not working’ is closed to new replies.
