In form and function would it not be better to compare Inset Faces to Loop Cut and Slide, after all isn't the extrusion as…
Forum Archive In form and function would it not be better to compare Inset Faces to Loop Cut and Slide, after all isn't the extrusion as…
  • #3852
    gfjarvis3
      In form and function would it not be better to compare Inset Faces to Loop Cut and Slide, after all isn’t the extrusion aspect a secondary operation performed after inset?
      #21792
      gfjarvis3
        Thank you Jonathan. After I posted the question I took a look at the python code for this area of the tool shelf. It would appear that all of those functions are closely related.
      • The topic ‘In form and function would it not be better to compare Inset Faces to Loop Cut and Slide, after all isn't the extrusion as…’ is closed to new replies.
