In constructing a movie that may include a series of stills, do you typically render the zoomed and panned slide show and …
Forum Archive In constructing a movie that may include a series of stills, do you typically render the zoomed and panned slide show and …
  • #5333
    Joe Dell’Orfano
      In constructing a movie that may include a series of stills, do you typically render the zoomed and panned slide show and then import the rendered strip to your movie project or do you include these multiple scene strips in your overall project? Thanks.
      #23711
      David McSween
        Best practice would be to render the 3D scenes first then import the image sequences to the VSE. However, this limits the flexibility offered in the approach above.
        Here I am suggesting a more interactive use of the 3D view so that you can visualise the effect of motion ‘between’ adjacent scene strips. That is you could zoom into one point of an image, then place the following image in the correct place to zoom out again. If you pre-render the animations you’ll loose that ability.
        Remember that rendering in OpenGL mode is very fast, so any mistakes are easy to fix.
      • The topic ‘In constructing a movie that may include a series of stills, do you typically render the zoomed and panned slide show and …’ is closed to new replies.
