In baking AO, why is it unnecessary to check "bake from multires", even though it's necessary in baking displace map?
Forum Archive In baking AO, why is it unnecessary to check "bake from multires", even though it's necessary in baking displace map?
  • #4617
    rickyi
      In baking AO, why is it unnecessary to check “bake from multires”, even though it’s necessary in baking displace map?
      #22853
        I’m not sure why it works this way, but when baking AO the system looks at the render resolution of your multires set by in the modifier – regardless of the “Bake from Multi-res” option. There must be separate algorithms for the displacement, normal, and bump bakes that are triggered by the “Bake from Multires” option.
        #22854
        rickyi
          Wow, thank you for replying Mr.Kent! OK, seems blender sometimes these kinds of hidden settings like pose library doesn’t record bones with prefix “DEF”. But that doesn’t change the fact that blender is awesome.
          Also, your tutorials are always great and have been helping me a lot. I’m looking forward your next tutorial! Thanks every time!
        • The topic ‘In baking AO, why is it unnecessary to check "bake from multires", even though it's necessary in baking displace map?’ is closed to new replies.
