Importing an FBX file with Animation into Blender
Forum Archive Importing an FBX file with Animation into Blender
  • #17492
    Deepak Jai
      Hi,
      I have an FBX file with a Knight character and an Idle Animation defined on it. The Knight Character looks upright in the FBX File as shown below.
      When I import the FBX file into Blender, It looks mangled as shown below:
      What settings do I use in Blender for the character to appear upright as in the FBX File?
      Both the files could be found at: https://we.tl/t-HutVPQ45mk
      Note: I am using Blender 3.0.0
      Thank you.
      #84084
      Adrian Bellworthy
        When importing into Blender the .fbx file should contain orientation data.
        Manual Orientation should be disabled (default) in the import settings to use the data in the .fbx file.
        If you are having issues, you may need to enable Manual Orientation and specify orientations.
        What I set below is Blender specific orientation, what you use may be different, depending in which software the model was originates from.
        #84085
        Adrian Bellworthy
          I downloaded the model you supplied,
          The model imported OK for me with the default settings, however the bone orientations where a bit messed up.
          The best setting I found is, all default, except under Armature enable Automatic Bone Orientation.
          #84086
          Deepak Jai
            Hi Adrian,
            Here is a snapshot of my import settings:
            The Manual Orientation is disabled, and the Automatic Bone Orientation is checked, but still I get the following
            I was wondering if you had an opportunity to import from the provided FBX file and if so, could you please send a snapshot of the import settings that worked for you. Also the version of Blender.
            Thank you.
            #84087
              Hi @deepakj ,
              I have no experience with Import/Export, but I tested your .fbx in 2.93, 3.0, 3.1, 3.3 and couldn’t get it to work as it should.
              But in 3.6 all was as you’d expect (default settings, with auto bone enabled):
              #84088
              Deepak Jai
                Thank you so much Martin. I’ve tried various import settings but it didn’t cross my mind to try a different version of Blender. I just tried it with Blender 3.6.0 and it works.
              • The topic ‘Importing an FBX file with Animation into Blender’ is closed to new replies.
