I'm hitting to use the Polystrips Tweak tool, while in Polystrips mode. Nothing is happening. What am I doing wrong?
Forum Archive I'm hitting to use the Polystrips Tweak tool, while in Polystrips mode. Nothing is happening. What am I doing wrong?
  • #6204
    I’m hitting to use the Polystrips Tweak tool, while in Polystrips mode. Nothing is happening. What am I doing wrong?
    #25037
    Correction: I’m holding down the T key, while using Polystrips, to use the Polystrips Tweak tool. (Not the regular, stand-alone Tweak tool.) The video says to hold T and you can tweak things while using Polystrips. Nothing happens when I hit the T key. Anyone know what I’m missing? I’m sure that I’m just missing some step.
    #25038
    Answer found! Carter2422 answers another person with this problem. You have to apply transformations (transform, rotation, scale) on both source and target. I had a 90 degree rotation on my source object. I applied that, and the T hotkey for Polystrips Tweak will now work.
  • The topic ‘I'm hitting to use the Polystrips Tweak tool, while in Polystrips mode. Nothing is happening. What am I doing wrong?’ is closed to new replies.
