I’m having a hard time cutting the grooves on the corners. I feel like there’s a more precise way to do it than knife the 4 corners, but struggle with subdivide. Is there a better approach than knife?
Forum Archive I’m having a hard time cutting the grooves on the corners. I feel like there’s a more precise way to do it than knife the 4 corners, but struggle with subdivide. Is there a better approach than knife?
Viewing 10 posts - 1 through 10 (of 10 total)
  • #6657
    Aaron Junod
      Aaron Junod
        Awesome thank you very much!
        #25729
        Alexander Khorkov
          Thanks. A perfect example!
          #25730
          Alexander Rengel
            Thank you so much.
            #25731
            Joseph Stout
              Thank you for this Explanation Jonathan!
              #25732
              Ivan Makarov
                A small addition to the solution from Jonathan: use Select Mirror to quickly select the similar faces.
                P.S. I used the Pie Menu addon for the Pie menus. It can be enabled here: Edit->User Preferences->Add-ons->Pie Menu
                #25733
                Tester Bonus
                  Thanks
                  #25734
                  quel47
                    This is a cool shortcut, you could also after selecting the area instead of mirror you could select same perimeter, although your way is slightly faster
                    #25735
                    the_red_pill
                      To quickly select the faces of all the corners simultaneously after you’ve subdivided, select the 3 faces around a corner, then:
                      Select -> Select Similar -> Face Regions
                      This will select all the additional 21 faces of the other corners in one fell swoop.
                      Then -to select all the insets of the cube at once, select one of the inset faces, then:
                      Select -> Select Similar -> Area
                      PS: I’m new to Blender and I’d like to know- is there a shortcut for the “Select” menu? I can see it becoming tedious having to move the mouse and actually clicking the Select menu item at the bottom everytime I need to.
                      #25736
                      apadavano
                        so helpful!
                      • The topic ‘I’m having a hard time cutting the grooves on the corners. I feel like there’s a more precise way to do it than knife the 4 corners, but struggle with subdivide. Is there a better approach than knife?’ is closed to new replies.
