if you separate the eye into two objects, parent them both to the lattice, and remove the project uv from the back piece, …
Forum Archive if you separate the eye into two objects, parent them both to the lattice, and remove the project uv from the back piece, …
  • #5339
    allofyoush
      if you separate the eye into two objects, parent them both to the lattice, and remove the project uv from the back piece, problem gone.
      #23723
      Chris McFall
        Nice Idea, But if I remember correctly, you can achieve the same quite easily with Vertex groups, however if the projection moves 90 degrees it will still project through on the front vert group/half.
      • The topic ‘if you separate the eye into two objects, parent them both to the lattice, and remove the project uv from the back piece, …’ is closed to new replies.
