If models are not snapping together in Unity and appear to be transforming from the Center rather than the Pivot point…
Forum Archive If models are not snapping together in Unity and appear to be transforming from the Center rather than the Pivot point…
  • #8109
    Adam Janz
      then you need to go to the top left of your Unity window and where it says, “Center” click it and change to “Pivot”. You may also need to delete a model you duplicated and re-transform it if you had already attempted moving it while it was incorrectly snapping. (Also, the global button switches between global and local transform space, just like Blender).
      #28179
      Adam Janz
        Well now I feel dumb… I posted this literally just a few seconds before Kent said it himself in the video. That’s what I get for pausing a video too early and immediately following along… ha ha! 🙂
      • The topic ‘If models are not snapping together in Unity and appear to be transforming from the Center rather than the Pivot point…’ is closed to new replies.
