If I have more round mesh with a subdivision surface modifier on it, should I remove the modifier in the low poly version, or should I apply it and work from there?
Forum Archive If I have more round mesh with a subdivision surface modifier on it, should I remove the modifier in the low poly version, or should I apply it and work from there?
  • #7190
    Ethan Meier
      Jonathan Lampel
        I would definitely remove the subsurf for the low poly, since applying it would make the mesh much too dense, unless you really need all that detail. You can also just uncheck the eye and camera icons on the modifier to disable it, so that it’d be easy to get back or preview if you change your mind later.
      • The topic ‘If I have more round mesh with a subdivision surface modifier on it, should I remove the modifier in the low poly version, or should I apply it and work from there?’ is closed to new replies.
