I'd like to know how to reduce the noise on the bake, What would be optimal sampling for a high quality bake? I am bakin…
Forum Archive I'd like to know how to reduce the noise on the bake, What would be optimal sampling for a high quality bake? I am bakin…
  • #4448
    Hardus Jonker
      I’d like to know how to reduce the noise on the bake,
      I am baking a car paint material, like in the shader forge.
      When I have baked the image, it is really dark and I have to use an emission shader on a really high setting. It looks fine but I can see the noise from the sampling.
      When I increase the sampling I don’t see a difference.
      #22556
        Your bake should exactly represent your render. If it’s turning out darker than your render, then something is wrong. Unfortunately there isn’t a standard ‘noiseless’ sample setting. It’s always uniquely dependent on each scene. But 1000-2000 usually gets rid of noise in my opinion. General rule: If there’s noise, keep increasing the samples.
        #22557
        Hardus Jonker
          Okay thank you, on 2000 it started looking pretty good. It has probably been mentioned somewhere, but does lighting also affect render noise?
        • The topic ‘I'd like to know how to reduce the noise on the bake, What would be optimal sampling for a high quality bake? I am bakin…’ is closed to new replies.
