I Want to Share With You Guys, the “Solve All Blender Sculpt Problems” Button
Forum Archive I Want to Share With You Guys, the “Solve All Blender Sculpt Problems” Button
  • #9787
    Heath Rowell
      It’s rad. So check it.
      User Preferences > Add Ons > Search for Mesh: 3D Print Toolbox > Add the Bad Boy
      Go to Edit Mode and select your mesh.
      Click on the new “3D Printing” tab on the left side.
      There will be a section called “Cleanup:” and more specifically the button “Make Manifold”.
      Many of you will probably be aware of the hotkeys for non-manifold edge selection and the various steps you have to go through to solve things after using it. But you click this button and it does it all for you. Instantly.
      Fill holes? Check.
      Solve bad geometry? Check.
      Make Normals Consistant? Check.
      Delete Duplicate Geometry? Check.
      When things aren’t working in Sculpt and you’re suddenly like “Man I don’t even know where to begin to fix this, let alone have the time to troubleshoot what is even going wrong with the mesh in the first place …” you can now, instead, say “FFFFFFFFFFFFFFUUUUUUUUU make manifold button.”  Bam. Problem solved.
      I present to you, the happiness button.
      #37424
      plasmavoyage
        Never even heard of that button, but I shall give it a try! 😀
        Thanks
        #37425
        Pavel Mazanik
          Yeah. You could just post a link to Zacharias Reinhardt video 😀
          #37426
          Heath Rowell
            I could have, if I could have remembered which video I saw it on. I was actually trying a plethora of different potential fixes from different opened tabs and lost track of which one was what. But that was definitely it. @nekronavt
          • The topic ‘I Want to Share With You Guys, the “Solve All Blender Sculpt Problems” Button’ is closed to new replies.
