I try to extrude an edge and it doesn’t do anything
Forum Archive I try to extrude an edge and it doesn’t do anything
  • #14768
    erikitect
      So I got to the stage where I have the quarter-circle with the mirror modifier on to make a half-circle, and am trying to pull the edge out to make a tab. I select E to extrude, select the edge, and try to drag it, but nothing happens.
      What am I not seeing?
      #72760
      erikitect
        Never mind. Solved the problem. What was wrong was snapping was on and I was not near anything that could be snapped to, so nothing happened when I dragged. This made me think something was wrong with the software. But turning off snapping fixed it.
        #72761
          Glad you resolved it! Thanks for sharing the solution in case others run into this.
        • The topic ‘I try to extrude an edge and it doesn’t do anything’ is closed to new replies.
